Can anyone explain the pros and cons that exist between a 2.0” coil over and a 2.5” coil over? Or rather the difference between the 2.0 and 2.5 inch coil overs?
And has anyone been able to run the 2.5’s using full width axles (69.5” WMS) and sunk-in frame mounts? Is there enough room for packaging and tire clearance for up travel/full bump?
Keep in mind that I’m comparing 2.0” vs 2.5” from the same brand and both using remote reservoirs. Also worth mentioning, I would be hitting roads, interstates, and hardcore trails in the Jeep.
