To make a long story short, my '05 2.4L TJ has been crank-no-start since I got it last year, and I suspect the Crankshaft Position Sensor (CKP). I've replaced the spark plugs, checked fuel pressure, replaced spark plug wires, and more.
What is odd is that I found two (2) CKPs actually installed in the engine, and I've found very little information on this engine in this vehicle online. I did find another thread (https://www.wranglerforum.com/threads/replacing-crankshaft-position-sensor-2-4l.2342047/) showing the sensor being on the passenger side, underneath the oil filter, which matches what the FSM says about the location. However, in this location, what I found on this Jeep is that there was a CKP bolted in but without the connector: snapped off and ground smooth!
I found another CKP installed on the driver's side of the engine, near the starter, and towards the back of the engine, which is what some other online information says the location should be for some of these 2.4L Chrysler PowerTech engines. This one did have the wires connected to it, matching the diagram in the FSM. I've not been able to find anything online about definitive location for this engine, and especially nothing about having two!
Does anyone have clarity for me on what the correct location is for this sensor on this engine, or anything on why there would be two installed? I've attached a couple images that should show the situation.
Thanks in advance for any help on this!
