Itake time to change the oil on my new 97 2.5 TJ. It’s got the (I’m pretty sure is the) lifter tick. According to the sticker inside it’s got 5w30 which I think is too thin. I live in Georgia. I had read about possibly using ATF to add in the old oil, run for a little bit then change the oil and helps the tick. Curious if anyone else has tried this and had results as well as if there is a particular kind of ATF I should use. Thanks all
