Chasing down an occasional engine misfire that makes the jeep buck/hesitate.
Happens when the engine under load, but not consistent.
I have replaced, with Mopar parts...
Crankshaft sensor
Distributor and rotor and plug wires, all Mopar. 174k on the clock. 30rh automatic.
No engine codes whatsoever.
Plan is to try a Mopar camshaft sensor next week.
Could the coil be weak or wearing out? ...idk
Could a failing camshaft sensor show this symptom?
What else could cause this? with no engine codes, may have to throw parts at the problem, ugh..
Crankshaft sensor
