Has anyone got an pic of a similar set up ?
Thanks
Andy
Thanks
Andy
This is probably 31s, but not terribly far off. Spotted it in a local parking lot and only took the one pic.
Factory rims still? I presume wheel spacer? If so what did you need to run to clear things.
Thx!
Thanks again, just collecting info on running 33’s in 10.5 wide. Those master crafts would be 12.5 wide? I also have the same rim 15x8 which I measured a 5.25 back space- so I think I could get away with 1” spacer on my narrower tire choice. Appreciate the info.
You can run 10.5" wide tires on stock wheels with no wheel spacers. You might have to add a small washer or two on the steering stops to keep the tires from rubbing the lower control arms at full turn. Much cheaper than wheel spacers.
I’m in the over 50 crowd. LolI enlarged your pics for the over 50 crowd and legal stoners.
p.s. Beautiful Jeep.
Hate scrolling thru posts with full size photos, even worse on mobile.
What is this mobile you speak of?
I do plan on getting 2” spring lift. I have 30x9.5 now and seeing where that gets close at the control arms...i am thinking to keep full suspension function and steering a 1” spacer gets the back spacing for the 10.5. As you mention I can put some limiting component in as I work through the transition. I am thinking of trimming the factory flares- Those high lines (preferred) or body lift will be a long term solution. Gotta keep promise to keep it low for the misses. One last question Doug- no track bar mods. Relocation or new bar at that 2”? Are you seeing a slight offset where one side is tighter than the other?
My wife can get in it still but it’s a struggle being under 5’. lol Same friend with the 40s has the Rock Hard trail step for his wife. It’s a nice piece.
