2000 jeep wrangler tj with 2.5l
Derekstockton
Tennessee
I am looking to level my jeep. I bought a 1.5 inch front / rear rough country kit(coil spacers and n3 shocks) Then I realized this would be 1.5 both front and rear and it would not be level.
If I only put in the 1.5 inch in front would this level it out or be to much ?
I plan on still using the shocks but I may have to buy new coil spacers to be level.
Any recommendations ?
Thanks
I wanted to level my TJ front with no lift in the rear. I went with a 1.25 inch spacer for 20 bucks, paired them to rancho rs5000x 0-1 inch lift shocks. 1.5 would have been on the dime for my 2006 x with soft top...I'm pretty sure it depends on the weight of your rig. You can take a tape measure from your tire to fender front and rear on a level ground.
You can also install the lift anyways and then throw spacers up front. You will probably have to get new front shocks in that situation though.
