Quick question. I pulled the throttle body and cleaned it out. Pulled the IAC valve and cleaned as well. Installed with a new Mopar gasket and torqued it to 100 inch pounds as that's the spec I could find. When started in the cold, around 0 Celsius, it revs to 2-2100 rpm. After about 30 seconds it begins to drop and seems to settle at 1100. Once driven and at operating temperature, idles around 800. Double checked for vacuum leaks and couldn't find any. Not sure if this is correct but wasn't like this before. It's a 2002 with the 4.0 and five speed transmission.
