Hi guys,
a new-to-me 2000 Jeep TJ Automatic 32RH, not long after a water pump change started whistling. Usually 30 seconds after startup, at idle, it would start and continue into the driving cycle and would last until I shut the engine off. If would happen in all gears and while driving from 750 rpm to 1600rpm, it would go away once over 1600 in "D". If I was in Park or Neutral and I couldn't get it to stop by revving no matter how high the rpm. While poking around I ruled out accessory belt/idler puller/bearings and also ruled out vacuum leaks. I did break a transmission cooler line where it connects to the front rubber hose, nad once repaired the whistling went away. But now, 3 days later, it has returned. I would need some ideas of what to do from here please.
Thanks for your help.
