2000 TJ dies after start
JGregurich
Omaha, NE
We just put a new alternator in last week, battery checks out good. Started the vehicle this morning and it sputtered a little but and then died. Just filled the tank with gas as well, only have driven about 5 miles since the new gas, tank was almost empty and took 16 gallons.
Thank you in advance for any information you can provide.
John G.
Any codes? Either use a code reader or use the key trick. Basically turn the key from ACC to Run 3x without starting and any codes should flash across the odometer followed by "donE"
