Newb here with afuel related question
I was changing out the the fuel pump on my daughters 2000 tj 4 cylinder and have came across a few problems. the fuel return line has corroded right above the rear spring. For now can use rubber gas line for a few inches and attach it to the proper fuel line to the tank? Secondly the blasted pipe return line on the gas tank lis cracked. Is there a fix for this or is this a case of getting a new tank.
Thanks in advance
Steve
Thanks in advance
Steve
