2000 TJ Sport with 6 cylinder and manual trans. Horn was working when I purchased vehicle, but has since stopped. Both horns work when 12 volts is directly applied. Fuse is good. Replaced horn relay with fuel pump relay and still didn't work. Searching threads for this problem seems to suggest that when the clock spring mechanism fails, the horn doesn't work or continuously sounds and the air bag light is on. The air bag light doesn't stay on after start and the cruise control works. Is a non-functioning horn only indicative of a failed clock spring?
Thanks!
Thanks!
