Horn issue
4x4fam
Florida
Hi all, Horn is in op on my 97 TJ. No airbag light, wipers works, turn signal works ( no cruise control). The horns work with jumper wire, fuse is good, relay is good (swapped) power on the relay checks good…. Horn bottom or clock spring?
It's been a long time, but I seem to remember the '97 models being a little different than the later models as far as the horn setup goes. Does yours have a dual horn or single?
Dual horn set up, and they look stock
Okay, so yours is probably setup like my '97. Check the cigarette lighter socket for power, if it is dead check the fuse that powers it. On mine if that fuse blows it takes out the horn as well.
Cigarette lighter socket has power, use it everyday for Bluetooth adapte.
