Pennsylvania 2001 LS Swapped TJ
Jmr17320
Gettysburg PA
Price
12000
Fairfield PA 17320
2001 Jeep TJ V8 LS swapped.4.8L 4L60e (donor vehicle 2001 GMC 140k miles). The Jeep runs the GM computer and stand alone wiring harness (installed clean to make it look factory). I have detailed notes that explain how everything is wired. Gauges all work except the CEL (covered as I hated looking at it) and tachometer (you can purchase a Novak converter if you want that to work). Rear is a Ford 8.8 rear differential with trussed kit and disc brakes. SYE and Tom Woods driveshaft. 4.10 gears so this can run 80 mph all day long. Skyjacker 4” lift dual rate springs w 1.25” body lift 35” MT tires. New Core 4X4 adjustable control arms (all 8). New radiator. Dual exhaust has upstream O2s but no cats. Frame had typical rust (center and rear CA areas) but has been patched with the appropriate repair kits. New radiator.
$12,000
https://www.facebook.com/marketplace/item/1011030745212310/?mibextid=6ojiHh
