I just replaced the gasket on my transmission pan, and once I filled it back up with fluid I started getting a leak from the transfer case weep hole.
Transfer case also has ATF-4 but wasn’t leaking until the tranny fluid went in.
Does that tell me it’s the transmission output seal, or could it be the Transfer case input seal? If the transfer case seal were bad wouldn’t that leak regardless of the tranny fluid level?
The skid plate is currently off, so I need to disconnect both driveshafts and drop the transfer case, correct? If it’s the transmission output seal, should I drain that first? Will the transmission fluid pour out once I pull the seal?
Found this great write up https://wranglertjforum.com/threads/how-to-replace-leaking-seal-between-32rh-transmission-and-transfer-case.13170/
Any other links to write ups or videos on this job are greatly appreciated!
Thanks for the help!
