Based on your other thread you're wanting to adapt a 32RH to a 42RLE harness, correct?I have the 2002 harness I put in it now, everything plugged up except the 4 wire transmission connector!
I put a 2002 harness back in it and everything plugged up except the transmission! My wire harness has one 4 wire plug but the transmission has 2 plugs, 1 is 2wire(tcc lockup) and the other 3 wire nss switch! I need the short adapter to connect the 4 wire plug to the 2 plugs on the transmission
