Hey guys, I just developed an issue with my 2002 4.0 automatic.
Jeep runs and drives great, starts just fine in the morning. But say I park at a gas station and come out to start it 5 minutes later? The jeep will crank endlessly but will not fire up. If I wait another 10-15 minutes it will fire up just fine on the first crank.
-Battery voltage is good,
-Connections are good,
-All fuses are good,
-Replaced crank position sensor (I heard this is a known issue apparently?)
I tested the fuel pressure today at the rail and it’s reading 50psi when the key is in the on position. With the engine running it’s reading 100psi. It looks like my fuel pressure is ridiculously high. Is this the cause of my start issues? And does anyone know how to diagnose and correct this high pressure issue?
Thank you,
Thank you,
