I don't want to bore you with another fuel pump story, but I have a question about the operation of this thing. I put a fuel pressure gauge on my 2002 4.0 to diagnose the hard starts. I had the fuel pump replaced by a shop a little over a year ago. Now it's doing it again. The pressure test showed zero pressure prior to starting. Zero pressure with the key in the "Run" position, and quickly built to 50lb as soon as I started cranking it. It started on the second try, as normal these days. When I shut it off, the pressure leaked back to zero within 15 seconds or so. I was thinking the pump would turn on with the key in the run position? Is this correct, or should I be diagnosing an electrical issue as well? I have ordered a new delphi pump and intend to drop the tank on Friday.
Thanks in advance for all your help.
God Bless,
will
God Bless,
will
