The camshaft synchronizer unit on my 03 Rubicon has started ticking. I removed the camshaft sensor and the pulse ring is wobbly. Is it okay to drive it this way or am I risking way too much? Like an engine failure?
Thanks!
Thanks!
I suppose that could happen. Failure for most people probably would result in the vehicle not running. I was born under a bad sign, failure for me would take out the engine, transmission and both differentials and flatten the spare tire.Not to question the people helping me but wouldn't a failed OPDA just mess up the timing and result in a non-working engine as opposed to destroying it?
Wouldn't that make the oil pressure gauge react therefore giving me enough time to pull over?When the OPDA fails it can take out the oil pump drive. (Actually it is the oil pump drive.) And that can do more than just make it not run.
Well you can swap it pretty easy...getting a crown one up to delta is the hard part. Napa is good for a lot up there, but its not the part you need. TimAnother question with regard to the OPDA. Is there any way to see if it has been replaced? I have an 06 LJ with the 4.0 (60K miles). Have been considering replacing as stated above “as a maintenance item”. But hate to do it if it has already been changed
I actually can get a Crown on Amazon, Just trying to determine if the one on the jeep is a crown, OEM or other manufacture. Looking for markings etc...Well you can swap it pretty easy...getting a crown one up to delta is the hard part. Napa is good for a lot up there, but its not the part you need. Tim
Just for shits and giggles. Since the OPDA controls when the engine fires and turns the oil pump, how can the OPDA stop firing the engine and keep it running long enough to run it out of oil pressure? Or, if the oil pump drive gear fails, how will the tone ring keep turning to keep the engine running without oil pressure?When the OPDA fails it can take out the oil pump drive. (Actually it is the oil pump drive.) And that can do more than just make it not run.
Things that make you go...HHHHmmm!!!Just for shits and giggles. Since the OPDA controls when the engine fires and turns the oil pump, how can the OPDA stop firing the engine and keep it running long enough to run it out of oil pressure? Or, if the oil pump drive gear fails, how will the tone ring keep turning to keep the engine running without oil pressure?
Other things- how is it possible that so many people lack the ability or foresight to hop on Rock Auto, click on TJ, ignition, distributor, camshaft synchronizer, OPDA, click on part number and then look at the buyer's guide that tells you which years have what?Things that make you go...HHHHmmm!!!
