2003 Wrangler Sahara 4.0 w/42RLE Auto.
I had an incident last week that has me puzzled. I don't drive the Jeep much...usually just for weekend offroad trips and around my area every couple of weeks so it doesn't sit up.
I started it up the other day and it started right up but was running rough and threw a CEL within a few seconds of starting. I drove it for about 10 minutes and it continued to run rough till I parked it. Checked the codes and there were two: a Crank Position sensor and misfire on cylinder #2.
I suspected mouse/wiring damage since the jeep ran fine when parked just like they say on FB markeplace.... and it sits in a barn all the time and I've had issues with rodents. I traced all the wires related to the sensor and spark coil-bar. Everything looked fine but I unplugged/plugged everything checking for corrosion etc...and re-seated the coil bar in the process. Everything was clean w/no signs of bad connections.
Cleared the codes and started it back up...runs fine, drove it for about 50 miles over two days because I need to know I can trust it, no issues, no CEL.
I'm tempted to go ahead and replace the crank sensor but just the code isn't enough to be confident that is/was the issue(parts cannon). Also, with parts quality of late I dunno if a new replacement sensor will be reliable. Even with mopart OEM...I mean, lets face it, Mopar is crap these days(sorry). Anyone have similar experience?
One note about the Crank sensor for future google searchers
I found TONS of videos showing all about it...but they all showed the sensor on the top-driver side of the transmission bell housing. I spent a lot of time looking for it in the hard to see wrong place because the later years with the 42RLE is in a completely different location and actually much easier to access and replace. Since this was only the case on the last few years of TJ production it takes some digging to find out....particularly when a lot of the videos stated "All TJ's have it here...." The information is out there if you dig through the noise...I guess at the time some of the video's were made it was ALL TJs so that can be excused.
