I have a 1999 4.0 jeep tj sport with the 32rh. i have now swapped everything out for a 1995 ax15 transmission. everything is bolted up perfectly fine and i am running into a crankshaft position sensor issue. I bought a new sensor for it and it will fire for about 1 second before immediately dying on me. i have the auto pcm currently in and i’ve been reading that you don’t need to replace it but there will be a CEL. i have wired up the NSS so it turns over and everything but the crank position sensor just wont allow it to fully start
