2003 TJ Gas Tank
sjaramillo23
Logan
Hey, guys my gas tank has failed on my 2003 TJ Jeep Sport. It look's like Jeep doesn't stock any of these tanks and the prices on marketplace are pretty expensive. Any ideas where I can get one?
What do you mean it failed? Is it the pump that isn't working or do you have an actual issue with the tank itself?
The connections to the filler neck are cracked, so gas is leaking out on both connections. It's a yellow plastic piece. Went to replace the fuel pump and found this, getting a check engine code for an evap system leak.
You could clean it up and vent it out and have it plastic welded or do it yourself.
I've got a small stash of tanks preparing for my 97 to go out. 2003 and 04 I think are a two year tank.
Could also go Genright or Barnes.
-Mac
