Ok, the saga appears to be over for now. Following is a list of things done the final bullet point is what resolved the issue.
1. Replaced the throttle position sensor with auto zone sensor-did not work.
2. Installed mopar throttle position sensor-better or so it seemed.
3. Checked all battery wires and changed the terminals it appeared a little better.
4. Disconnected the clock spring for airbag and horn- no change.
5. Replaced the throttle position sensor connector, factory wires were a little melted-still no change.
6 added a small diameter ground wire from the battery to the bolts holding the pcm to the firewall- issue is gone.
I will be replacing the ground straps from the rear of the motor to the body and may add another one. Check your ground as 5 volt reference to the sensors will be effected by poor grounding.
