OK, I disconnected the positive cable from the battery, left it off for over an hour, then I went out and checked the ground on both the engine and the chassis. Reconnected the battery and started the jeep. No more engine light and it’s no longer in limp mode and drives just fine. However, I have a new symptom which is when I’m backing up or going forward slowly it’s stalled on me about three times. It restarts immediately so if stalling is the only thing it does, I can live for that until I ultimately fix this problem. What do you guys think? Was this just a glitch or do I need a new PCM… If I do I’m going straight to Mark at Wrangler fix.
