2004 TJ problem
Dan2004TJ
New York
so I have a question for Tj experts I own a jeep wrangler rubicon 2004 is my 3 year with it I have an issue so I have leak on my transmission and the light on dash pop out as a “transmission pump leak” so I’ve read that usually the transmission gasket could brake and I’m thinking that’s the issue because the transmission don’t make any noise at all and other thing so when I’m on the highway the rpm gauge won’t go up to 3 and stays in there first I had an CO2 censor problem so I change the censor but after that the “transmission pump leak” came out so now I’m thinking is the gasket so what are you think I could be ?
Google "wranglertjforum" and the code you're getting. Or scroll down a bit...there are two or three active discussions about your 42re.
-Mac
