California 2004 TJ Rubicon carpet, steering, wheels, tires, air compressor, etc.
RubiconRic
Sarasota, FL
Price
Various
Oceanside, CA
Hi All, I'm moving from Oceanside, CA to FL next week and need to clean out the garage. I've highlighted some Jeep/garage stuff below you guys might be interested in. Everything is in disarray so I'll add pics as I dust stuff off but if you want some sooner just let me know.
JeepOEM carpet w/ front mud mats included - black - maybe 50k miles
SOLD​
JeepZJ steering upgrade (I replaced with Savvy/Currie) - maybe 30k miles? - this was used in FL so nothing ever came into contact with tie rod or drag link - it would need new TREs
SOLD​
JeepBudget Boost - 2" coil spacer set (front & rear) - only the spacers; no bumpstop extensions
$20​
JeepWheels & Tires - Qty (4) 15x8 5x4.5 3.75bs Pro Comp Series 97 in gloss black w/ 34x10.50-15 LTBs ranging from 0.16-.34 tread (good for temp rolling or spares)
SOLD​
JeepWheels & Tire - Qty (4) 15x7 5x4.5 4.5bs wheels PAINTED BLACK (like this: http://www.midwestwheelcover.com/9012usedrims.aspx, except painted flat black) - one of them has an old 33x12.50-15 MT/R (original) w/ 0.167" tread so good for 33" spare - three of the the center caps are the PN 9008 from below, painted black, with a yellow ring around the outside - i.e. would look great on a yellow jeep, or you could repaint. I'd include the (3) 9012A and (1) 9008 for free.
SOLD​
JeepCenter Caps - Qty (3) PN 9012A (like this: http://www.midwestwheelcover.com/9012centercap.aspx) - excellent condition
SOLD​
JeepCenter Cap - Qty (1) PN 9008 (like this: http://www.midwestwheelcover.com/9008centercap.aspx) - excellent condition
SOLD​
JeepOEM Brake Calipers w/ BMB pads - front set - calipers painted yellow w/ Duplicor caliper enamel - pads have 10k miles on them - both pistons seized and I just bought new calipers rather than replacing the pistons bc I figured I could do that at my leisure and keep as spares - as a result of pistons seizing both pads got to around 500F and the pass side prob got even hotter - driver side has new boots/slides
SOLD​
JeepOEM Knuckles - front set - recently painted black w/ Eastwood Rust Encapsulator - with 97k miles - both have dimples that would need to be welded and ground
SOLD​
JeepOEM 4.10 TJR Dana 44 gears - front & rear - prob ~90k miles
$0​
JeepSprings -
Front set: OEM '98 ZJ (1" lift) - mileage >100k
Front set: OEM TJ Rubicon springs (I had them on the rear for about 30k miles as 3" lift on a budget) - mileage ~90k
SOLD​
GarageAir Compressor - Central Pneumatic 21gal 125PSI 2.5HP w/ inline filter - vertical - HF# 67847
SOLD​
GarageShop Press - 20ton - HF# 32879 (orange) - used for one gear job
SOLD​
GarageShop Vac - RIDGID 16gal 5.0HP - #WD16360 - rarely used
SOLD​
GarageBench Vise - Irwin 4" - Model 4935504 - new in box
SOLD​
GarageWork Light - Dual Head Halogen on telescoping tripod stand - only one light works - looks like this https://www.harborfreight.com/fixed-dual-head-halogen-work-light-63974.html
SOLD​
Carpet and mud mats shipped to 78255? Also interested in front and rear springs.
Also interested in carpet... I'm going to assume it's for a full center console... but *hoping for a short center console so I can cover up the floor between my seats.
The work light... blown bulb or more issues than that? Simple enough I'm sure it could be repaired. My garage lighting SUCKS.
Carpet only: UPS says $60 and I found a website called Onlineshippingcalculator that works with Shippo where it says the UPS rate is $29.
Does anyone know if Shippo is legit?
As for springs, I just looked at them and my posting is wrong... I forgot I had '98 ZJ springs on the front and my stock front springs on the rear. Basically for my Jeep they raised the front about an inch and the rear about three inches. I was running that setup with a 2" BB spacer in the front only for the equivalent of 3" lift all around. Are you still interested?
My Jeep has a factory sub console if that helps? Not sure what short center console refers to.
Not sure... I was using the good bulb last night as I was packing bc the overhead light went out and I didn't have a replacement bulb. I also don't have a replacement bulb for the work light so I can't test the "bad" lamp to see what's wrong.
Looks like around the $60-70 range. The gears are awkwardly packed and don't seem to fit into standard flat rate boxes.
According to Onlineshippingcalculator and Shippo this would be around $31 through UPS... not sure if that's legit though bc I've never used.
Ah ok - no to carpet and springs then - thanks for quick reply.
Did these sell? I’d be interested. Ship to 43140?
Nope, haven't sold... pricing is roughly the same... says $35 through Shippo and $66 through UPS... right now they're in their styrofoam but if I repackage and ship in separate flat rate boxes it'd prob like $40 total. I have enough packaging material laying around I should be able to do it safely... just let me know what you think.
Job transfer, retire or just sick of California? I am the latter but still here.
