2004 Jeep TJ Rubicon 99” Long Wheelbase
Complete Super Rare AEV Highline Kit with AEV heat reduction hood...one of Dave Harriton’s most fantastic inventions. I love it!
Currently runs 35s perfectly @ 2000 rpm highway; can easily run 37s (5:13:1 gears required) or 39”/40” tire with existing Nth Degree and AEV highline combination...(recommend Dynatrac ProRock 60s w 5:38:1 gears if you want to run 39/40” tires)
Exterior color: OEM Jeep Light Khaki
Interior: Black Factory Rubicon
Miles: 220,000 but speedo reads 9mph fast
2006 4.0L w/ 50k miles installed in 2015
4-speed Automatic 42RLE with two (2) transmission coolers and Autometer Temp Guage...has always run cool
NP241OR 4:1 transfer-case (2006 w/ 65k miles)
Advance Adapters TJ Cable shifter for 241 (715543) Such a improvement over stock
ROCK HARD 4X4™ BOLT-IN ULTIMATE SPORT CAGE FOR JEEP WRANGLER TJ & UNLIMITED LJ 1997 - 2006 [RH-1001]
Truck-Lite 7” LED headlights, Brilliant lights and a SEMA show winner
PSC dual power steering & transmission cooler in preparation for PSC hydro assist steering gearbox
New 2018 Currie Enterprises Correctlync Heavy Duty TJ/LJ Steering System with Savvy Ultimate Steering HD Tie rod
Borgeson Jeep TJ heavy-duty steering shaft
Heavy duty elevated front sway bar brackets welded to front Dana 44
Old school 3-row CSF copper Brass radiator for superior cooling
Spare Mopar water pump new in box
Spare Mopar alternator
Rigid Industries D2 LED flood lights on A-pillar
IPF ARB Bull Bar incandescent off-Road spot lights...classic AEV look.
4:88:1 Gears
Factory Rubicon low-pressure Air Lockers Front/rear
Front/rear Superior Chromoly Dana 44 axles
Every single Nth Degree 6” Long Arm Suspension system option...Jim Frens full TJ realization of the ultimate on/off road suspension system.
This suspension was over $6000 at time of install and took two full days to install. It is also one of the last AEV sold Nth Degree Mobility long arm systems...
Nth Degree 4.0 Oil Pan and 42RLE transmission skid plates
Nth Degree TJ Tummy tucker
Nth Degree Dana 44 Diff Sliders front/rear
2018 New front/rear Adams 1350 CV drive shafts Extreme Duty Series
2018 New rear drive shaft built by Everett Drivelines (Spare Emergency Unit)
4x Spare Nth Degree Gyro-Joints and Elastomer cups - New In Box
ARB Front TJ winch bumper with Philips LED DRLs
8000lb Smittybilt X2O waterproof 8K Winch with Steel cable and Factor 55 Prolink
ARB Rear TJ bumper with Tire Carrier/Hi-Lift Mount...can hold 39” tire with 7x frame mount system with integrated class 3 hitch
5x BFGoodrich KM2 Mud-Terrain 35x12.50R15
5x Outlaw II 15x8” aluminum wheels
***I’ll include 4x JK wheel adapters if you want to run 17” AEV Pintler Wheels***
SPOD for TJ w/ 6-switch Panel and Air gauge
Magnaflow TJ high flow cats new in 2015
No check engine lights, runs perfectly, A/C works 100% and will pass emissions in all 50 states.
Smittybilt TJ Hardtop which is much higher quality than the factory hardtop with carpet headliner
New 2014 Rampage Frameless Trail Top Softop
Genright “Crawler” Alien 19 Gallon Stepped Aluminum Fuel tank for 5” rear axle stretch...new Mopar fuel pump 2015 and complete spare Mopar fuel pump.
Located just north of Seattle, WA...
Fly in and drive 1000-3000 miles home...I wouldn’t hesitate to take this anywhere.
If you are a serious buyer Contact me at:
Email: [email protected]
call/text 206.250.0668
PM me here on this Wrangler Forum Page
Free AutoCheck PDF on this 2004 Jeep Rubicon, just ask.
Clear WA Title, Clean, 2x Washington State owner Rubicon, No Accidents, Zero Issues...
Only selling because I have my eye on a very specific 4-door AEV JK350...I need more room for my two teenagers and our Great Pyrenees dog.
4:88:1 Gears
