I recently installed a B&M Precision Sport Shifter trying to fix the common "pops out of gear problem" on a modified TJ and it partially remedied this problem. I like the positive and shorter throws it now provides. I had to modify the shifter lever to prevent from engaging with the console shifter cover in gears 2,4 6 and R. It now works as it should. My modification eventually led to grinding the bottom bend in the lever for clearance. What I'm looking for is a new shift lever that will make the lever "more centered" in the console, moving it more towards the dashboard. I can certainly have one manufactured but would like to see if one is available before I go through the expense. Any thought or suggestions would be appreciated.
SaveShare
SaveShare
