- Price
- $1600
- Location
- Torrance, So. CA
NEW LOWER PRICE THIS WEEKEND ONLY 4/25 & 4/26!!!
For sale:
Complete Dana 44 front axle from an original 40K mile Rubicon LJ Wrangler with all steering linkage, brakes, hoses, rotors & locker air pump assembly.
This will fit with little to no modifications almost all TJ Wranglers, LJ Unlimited models that were not Rubicons, ZJ, XJ, MJ Jeeps and is factory stock from a Rubicon model TJ Wrangler. It was pulled when the owner upgraded to Dana 60 axles front & rear. It has the original 4:10 gear ratio and factory locking differential the famous Rubicons are known for.
This is a great upgrade at a killer price that is virtually "bolt-in" ready to go!
$1800 NOW ONLY $1600 pickup only in Southern CA near Torrance airport.
Clean off the rotors and turn them, drain & fill the diff with new gear oil, get an adapter U joint and wire/connect up the locker pump. You will be ready to challenge some of the toughest obstacles or trails.
text310-567-7724for details and to make arrangements for pickup if you want it.
Thanks for looking!
For sale:
Thanks for looking!
