I’m stumped! I have a new to me 05 Rubicon TJ. Runs and drives excellent and the amazon guy is starting to hate me . Let me start by saying I’m pretty good at troubleshooting and I have tried most everything.
The jeep is stock with no major mods except wheels/ tires. 4wd works in both low and high with a 4wd dash light on. Now the issue:
No axle locks, no lights on dash, replaced axle lock switch...still no lights or lock. However the dash lights do light the light in the switch so one problem solved. The other switch was dead. On to cb’s and relays. CB under hood is fine in fact all of them are fine. Rotated relays, no change. Replaced relays, no change. Pulled relays and jumped to see if pumps run, both run and appeared to lock the axles but still no lights on dash. So I’m thinking wiring between relays and switch. Ran continuity checks, all are good. Still frustrated. Went under jeep to check on wires and plugs which all appear good. So the good news is that both pumps work and seem to lock both front and rear axles. But I have no indication or control inside the jeep.
What turns on the front and rear lock lights on dash? Sensor? I have never even seen them blink. Will the mod solve this? And will the MOD allow those lights to come on on the panel? Thanks again. Dave
