2005 steering upper and lower steering shaft
Placilla
Arizona
I bought an '05 TJ and has lots of play in the steering. The steering shaft has lots of play and plan to start by replacing the lower and upper shafts.
But why am I having such a hard time finding them for an '05. The only thing I can find are the Borgeson one and they are costly. Everything else are for older models.
Any help or suggestions would be appreciated.
AndyG
TJ Guru
Lifetime Supporting Member
Alabama
You can find a stock replacement through crown or omix-ada possibly-
The Borgersen I got would not fit the bearing correctly and had to be returned-
Be sure to do the dry test and make sure the shaft is the problem.
Reactions: John Cooper
