Hi all. I know this has been discussed and I have done some research. I have the chance to buy a 2005 TJ Rubicon, auto, with low miles. No rust, sounds and looks to be in really good shape.
I've really wanted a 98-99 or 2003 TJ manual, but this is the Rubicon model and is super clean with under 60k miles. I don't think I'll find a better deal than this. It's an auto, which is less preferable, and has the dreaded risk for OPDA and PCM issues.
I don't plan to modify at this time, but use for a 3 mile commute intermittently, run up to the mountains, and do lighter trails and forest service roads. I would likely just get a PCM from Mark at wranglerfix and do the crown OPDA. Likely a Derale cooler and maybe a deeper pan.
Would I hate the auto if I have been wanting a manual? I've had the ax15 and NV3550 and prefer the ax15, but haven't driven the 42rle. With my intended uses though, the auto may still be fine and is easy to drive, as well as better trail control.
Thoughts? Thanks!
Thoughts? Thanks!
