SOLD 2006 65th Anniversary X (148k, 6-speed, 3.73, and Dana 44)
monto
Boston
Price
$9,900
Boston
2006 Jeep Wrangler X 65th Anniversary Edition
VIN: 1J4FA39S16P754953
148,250 miles
4.0L Inline 6 cylinder
6 speed manual
New 30" tires (< 1,500 miles)
Lifetime SIRIUS radio
OE options that make this X essentially a Sport;
3.73 Rear Axle Ratio
Dana 44 Rear Axle
Air Conditioning
Very clean inside and out and stock as far as I can tell.
CARFAX report available upon request. Reconstructed title. Minor damage to driver front listed (See pic).
After only having this Wrangler for a little over a month I came across a low mileage 2006 Rubicon locally that I couldn't pass up.
DOES NOT INCLUDE HARD TOP. I will be transferring to Rubicon. See pic of very clean, no rips or tears and all hardware, tinted sunrider soft top.
Any questions just ask!
BUILD SHEET
OPTIONAL EQUIPMENT
Two Tone Cloth Seats w/65th Logo
Dark Slate Gray
Tire & Wheel Group - 30"
Jeep 65th Anniversary Edition
4.0L ENG(ERH)/6SPD M/T NSG370 (DEH)
Easy Access Pass Tip & Slide Seat
Floor Mats w/65th Anniversary Logo
Full Length Floor Console
All Manual Transmissions
6-Speed Manual NSG370 Transmission
Heavy Duty Dana 44 Rear Axle
4.0L I6 Power Tech Engine
Light Tint Front Door Windows
Deep Tint Sunscreen Windows
Full Metal Doors w/Roll-up Windows
Sunrider Soft Top
Air Conditioning
Silver Center Stack Bezel
Courtesy Lamps
Underhood Lamp
Front Fog Lamps
Jeep 65TH Anniversary Edition Badge
50 State Emissions
Federal Tier 2, Bin 9A Emissions
Next Generation Engine Controller
Bright Silver Metallic Clear Coat
All Radio Equipped Vehicles
7 Speakers Inc Subwoofer/Tweeters
Fixed Long Mast Antenna
Sirius Satellite Radio
High Pressure Gas Charged Shocks
Rear Stabilizer Bar
30X9.50R15LTB Wrangler OWL A/T Tires
Goodyear Brand Tires
Black Easy Folding Soft Top
15X8.0 Forged Aluminum Wheels
Matching Spare Wheel
All Aluminum Wheels
Call SIRIUS to Activate@888-539-7474
1-Year Service Provided by SIRIUS
3.2 Additional Gallons of Gas
Spring - Left Rear
Spring - Left Front
Spring - Right Rear
Spring - Right Front
FAM: TJ TRACKING: 50916T04 MY:2006
FAM:TJ TRACKING: 51216T16 MY:2006
Customer Preferred Package 2TX
Customer Preferred Package 25X
No Charge Sunrider Soft Top
Paint Order Code
STANDARD EQUIPMENT
Convenience Group Monotone Paint 117 Amp Alternator 600 Amp Maintenance Free Battery Power Front Disc/Rear Drum Brakes High Back Bucket Seats Easy Access Driver Tip & Slide Seats Reclining Front Seats Rear Folding Seat Next Generation Front Air Bags** Front Seat Area Carpet Rear Seat/Wheelhouse/Cargo Carpet Cargo Tie Down Loops Sport Bar w/Full Padding Command-Trac Part Time 4WD System Dana 30/186MM Front Axle Tinted Windshield Glass Rear View Day/Night Mirror Swing-Away Mirrors Instrument Cluster w/Tach 100 MPH Primary Speedometer Var Intermittent Windshield Wipers Single Low Note Horn 12V Auxiliary Power Outlet Locking Glove Box DARK SILVER Metallic - Badge - Jeep, DARK SILVER Metallic - Badge - Wrang EXTERIOR COMPONENT COLOR Halogen Headlamps CHMSL Lamp Black Front Bumper Black Rear Bumper Black Bumper End Caps Chrome Headlamp Bezels Black Front Frame Overlay Body Color Grille Trail Rated Badge EVAP Control System 19 Gallon Fuel Tank Bright Silver Metallic Clear Coat AM/FM Compact Disc Radio w/Chgr Ctrl Power Steering Steering Wheel Front Stabilizer Bar Tilt Steering Column Full Size Spare Tire Outside Tire Carrier Upgraded OBD-II Connectors Fuel Tank Skid Plate Shield Transfer Case Skid Plate Shield Tethered Fuel Filler Cap Protective Coating and Remover Build To U.S. Mkt. Specifications GVW Rating - 4450# U.S. Dealer Retail Zone 32-New York TJ-Vehicle Family Four Wheel Drive (4WD)/(4X4) Left Hand Drive (LHD) Price Class H No Cargo Box Short Wheel Base (SWB) Vehicle Order Tracking U.S. Specifications Label New Hampshire Ship to State Code New Hampshire Sold to St
monto
monto
Boston
Hi. I'm interested!
Is there a lift? If so, how big?
Where about in Boston are you located? I'm in Hartford.
No lift. It's stock as far as I can tell which means you'll be starting with a clean slate. Can't seem to PM you so reach out through the listing on FB here;
I'm in the South End of Boston, not too bad a ride from Hartford. I know the Hartford/Manchester/Glastonbury area pretty well.
monto
monto
monto
Boston
So the satellite radio is lifetime on the 65th?
I didn’t do any research so I’m just reiterating what the previous owner told me but I can confirm it still works 15 years later without paying a subscription.
