2006 Jeep tj is giving me a fit!! Replaced the clutch and crank shaft position sensor and the nss. Bypassed the ignition switch for a toggle switch but it will not fire up!! Need help
2006 Jeep tj is giving me a fit!! Replaced the clutch and crank shaft position sensor and the nss. By passed the ignition switch for a toggle switch but it will not fire up!! Need help
Crank's but does not start or does not crank?
Any codes? With your '06, you can cycle the ignition from Off to On three times and any stored codes will be displayed in the odometer.
I think @Chris needs a sticky that explains the difference between will not crank over & will not start. Makes it difficult to help people when they don’t understand the difference.Can you clarify what you mean by 'fire up'? Does it crank & not start, does it not crank, etc...
Waste of time, people generally wouldn't read it and just ask anyways...which is why you see the same topics over and over and over and over...I think @Chris needs a sticky that explains the difference between will not crank over & will not start. Makes it difficult to help people when they don’t understand the difference.
Yeah, everyone has their own way of describing stuff, especially if they aren’t familiar with technical aspects.You mean you don’t like guessing and having to extract information from the OP
