Was driving yesterday in a lot of heavy rain. Ran thru standing water and shortly afterwards the guages , all,speedo,tach,fuel,temp, volts all went dead, jeep still running.. accelerated to merge and engine missed pretty hard. I pulled over and it was running like normal. I shut it down to try and pull the codes and all I got was a no link.. then it wouldn't start. After an hour of contemplating life and having the battery unhooked I tried it and it fired right up.. still no guages but no cel.. I proceeded to drive the 5miles back home and the cel popped on. Im not sure how fast I was going but don't believe I was over 45. If I tried to accelerate it would miss pretty bad.. I got home and tried to pull codes again and got nothing. Tried the turn the key methid and got nothing.. as a first effort, I replaced the crankshaft pos sensor.. didnt fix it. I'm at a loss now.. the Jeep will start if you hold the key and give it lots of gas.. idles good but if you step on the gas it starts to miss.. it has a newly rebuilt PCM from wranglerfix... Thanks for any help, rob mc..
