Yes I did, but that was relative to 4 to 6 cylinder frames. This is relative to 99 4L to 06 Rubicon. I was wondering if there was anything significant relative to the rubicon, apologize if it was too close a question, new to jeeps and want to make sure I fully understand what I am getting into prior to buying the wrong thing.
Regarding the steering box hole pattern, can the old pattern be drilled into the new to reuse my box?
On the skid plate, If I get the 06 skid plate with the frame, I assume it will work with my trans and tcase?
Thanks again for all the help
The 2006 Rubicon transfer case is larger than a 231 case found in all other TJs, so the skid plate is somewhat different. You might be able to have the 2006 plate modified, or pick up a 231 skid plate from a junk yard. Don't let the skid plate not fitting prevent you from buying a frame, if it's in good shape.Yes I did, but that was relative to 4 to 6 cylinder frames. This is relative to 99 4L to 06 Rubicon. I was wondering if there was anything significant relative to the rubicon, apologize if it was too close a question, new to jeeps and want to make sure I fully understand what I am getting into prior to buying the wrong thing.
The Rubi case being bigger affected all the frames and skid plates they used from 03-06 on all the models regardless if it has a 231, 241, auto, manual, six or 4 cylinder.The 2006 Rubicon transfer case is larger than a 231 case found in all other TJs, so the skid plate is somewhat different. You might be able to have the 2006 plate modified, or pick up a 231 skid plate from a junk yard. Don't let the skid plate not fitting prevent you from buying a frame, if it's in good shape.
Gotcha, thank you.The Rubi case being bigger affected all the frames and skid plates they used from 03-06 on all the models regardless if it has a 231, 241, auto, manual, six or 4 cylinder.
