Hey guys just got done wiring my led halos into a DRL fuse. Now I need to tap into the turn signal wire. There's three wires, a black(ground) yellow striped, and green striped on the drivers side and on the passenger side there is also black(ground) and yellow striped, but instead of the green striped it is brown striped. I need to tap into the wire that is not the power wire(which I assume is the yellow striped because it on both sides) in order for my halos to turn amber when the turn signal is activated.
Just want to be sure I tap the correct wire. Thanks!
Sent from my SM-G920P using Tapatalk
