So I put off replacing the selector shaft seal in my 99 for as long as I could, actually I just haven't had the time. As many of you know, there is very limited space to work on this seal and most seem to do the little tap tap tap to slowly drive the new seal in. I designed an attachment for my slide hammer that makes the install stupid simple quick and easy. I took a piece of 1/2 plate about 2x6 with a hole drilled in each end.(I cut this plate off of a semi truck mud flap mount that was in my scrap bin) welded a nut on one hole to screw onto the slide hammer and then used a 3 point hitch class 2-3 adapter sleeve (Tractor Supply) as the actual seal driver(Perfect size dia and length). I welded a bolt into the Category 2-3 adapter so I could change size if I ever needed it for a different seal. I also stuffed a piece of plastic into the tool to better center it on the shift shaft since the "driver" has a larger ID than the OD of the shaft, plus it protects the shaft from the possibility of metal on metal contact. It works incredibly well, a couple small bumps with the slide hammer and the seal was in and perfect. I also came up with a process to remove the old seal when a screw driver or seal remover will not work IE the seals with the metal almost touching the shaft if any body needs help with that.
PS OMG my transfer case / trans skid was FULL of ATF!
