White Shadow 99
I have a 06 LJ 42RLE and got harmonic vibs after regear. It starts at about 62 and is the worst at 67ish. I have 5.13 Revolution Gears, 4" Currie SA, 1"MML, 1"BL, Tummy Tuck on 35s. I have NEW CV drivelines front and rear.I have had them both rebalanced...it is not the wheels and tires. If I remove the F driveshaft no worries at all. My only issue is with the front driveline in. I have played with the pinion angles over and over again....I have check for rubbing of the drivetrain to the tub, replace the tranny mount, motor mounts are good. I have built race cars and I am supper anal, my CAs are matched to the MM, Trackbars are with in a 1/16 centered on the chassis. I have 'heard' that there is an issue with the 42RLE when both driveshafts are spinning at high speed, although some do not have our issues.....They only thing I can think of to do now is to check the trasfercase yoke for accuracy/run-out and possibly remove the MML. the MML only helps REAR driveshaft angle....it actually HURTS the F. transfercase yoke angle. F driveshaft is at 9 degrees and R driveshaft is at 13 degrees.
The only improvement that I have seen is when I remove the spare tire (weight behind the rear axle). My LJ runs a bit low in the rear as it is , but when I remove the spare tire (70 LBS) the LJ does not sag as much in the rear, this actually helps the F transfercase yoke angle.....and I observe less harmonic vibration at same speeds above. This helps my theory on the MML removal to help.....BUT I am so frustrated and tired of chasing this ghost and may end up with hubs as well or just turn up the tunes. FYI, my TJ has way more extreme angles on the driveshafts, a shorter rear shaft and no vibs. Another note, I don't beleive the whole tummy tuck will HELP pinion angles.....someone is going to have to explain that one to me. A Tummy tuck lifts the entire drivetrain, thus increasing the angle down to axles. When most people talk about improving driveshaft angle they are talkin about the rear......WE are talking about the front only, that is the issue here.
