Ok. Another baffling issue. I've searched around and can't seem to find a straight answer.
99 tj 4.0 standard
Cranks up runs fine for a few minutes then it just shuts down.
The gauges don't move apon shut down till it fully stalls out.
Does fine on idle. You'll drive sometimes it does it in first. Sometimes second. You usually can't make it past second. Then it just cuts out. And comes to a stop. Then sometimes it fires up. Sometimes it takes a few tries..
And ideas. Fuel pump is running.
New coil and plugs.
Any help is greatly appreciated.
Sent from my Z963VL using Tapatalk
99 tj 4.0 standard
New coil and plugs.
