Thank you for your input, exactly what I'm looking for. I am planning an LS swap, I'll just bite the bullet and do the LS swap at the same time. 5.3/th400 or 4l80e swapIs there a problem with your 42RLE or are you looking to solve the problem caused by its steep .69 Overdrive ratio? The TH400 is a power hungry transmission better suited to a V8 in my opinion.
Are the pans the same width? Would you retain the 231 or 241?Is it possible? Are the 05-06 LJ computers as tunable as the LS computers?
Ford drop or Chevy?Thank you for your input, exactly what I'm looking for. I am planning an LS swap, I'll just bite the bullet and do the LS swap at the same time. 5.3/th400 or 4l80e swap
If its a rubi 241, you could recoup quite a bit of it.Th400 will be backed by an atlas. I currently have a 241 but I'll sell it to offset the cost.
