so i found something i'm not sure i'm happy about.
the cooler seems to be functioning fine.
BUT.
when i shut the engine down all fluids return to the lowest points they can reach. this allows 1/2 the trans oil to gravity drain out of the cooler and back down into the trans.
so in theory the trans is as if it's way overfilled until the extra volume the cooler holds is pumped back into it and it is once again full.
parked/cold, the dipstick level shows it way overfilled. it's takes a few minutes for the trans to pump the cooler full then the stick reads just over 1/2 way between the add and full dimples on the stick.
i need to get it hot again and get that level right when the sys is functioning and the cooler is full, which means adding just a bit more oil.
how hard is pushing all this extra fluid gonna be on the trans itself? does this need addressed or corrected?
i wish i could get the cooler lower it the sys, this would limit drain back, but it's this or nothing for now.
