Hey guys fishing for ideas here. New Member, first post.
Got my first jeep this winter and noticed the rear brakes didn't seem to be working. In the snow i would have the press the brakes very hard to stop and a few times it would lock the front tires up, but the engine with still pushing the rears, had to put it in N to stop.
side note : the front brakes were also pretty bad but they tightened up very nicely once i did pads and rotors, they work great now.
I got the rear in the air and put it in drive, i pressed the brakes and had to press them to the floor and the drums still kept spinning slowly or would just barely be able to over power the engine. (the torque converter does seem very tight) So i popped off the drums (they slid right off) and found pretty much brand new hardware, almost no brake dust on anything.
I tried adjusting the brakes with no change.
I replaced the drums and scuffed up the shoes cause they seemed slightly glazed. no change.
bled the rear brakes, no change.
Replaced the wheel cylinders and re-bled, no change
The driver side is adjusted so far out i can barely shimmy the drum on and off. the passenger side slides off easily but for whatever reason stops better than the driver side. I check the self adjuster and its contacting the star. i tried driving around the yard for a few minutes in reverse, hitting the brakes, but it doesn't seem to have changed anything. It looks like all the brake lines were replaced somewhat recently.
We are stumped. I know there's a proportioning valve under the master cylinder. Could that not be sending enough pressure to the back? I've read on here that all that does is delay the application of the front brakes?
any help/tips would be appreciated. thanks in advance.
