Hello all,
So in the North East, we recently got very cold very quick. I daily my TJ so I am definitely aquatinted with new noises or behaviors that happen. All of a sudden yesterday, when the temps dropped into the teens for the first time this year, I now have a fluttering/squeaking sound coming from the front side of the vehicle.
Initially I thought it was just a bearing on the serpentine belt pulleys, but after some more testing, it is not RPM related. More corresponding to vehicle speed.
When the vehicle is ice cold, I will have the flutter/squeaking over 15 mph and it is its loudest at 25 mph, with clutch engaged or not. From research, it seems that this is the centering ball on the double cardan joint in the front driveshaft. When I put it in 4wd, the noise is gone under load it seems. But once the engine reaches temp, the noise is completely gone. I don't quite understand why the noise would go away once the engine reaches temp if it is a driveshaft issue, maybe after some movement the grease inside heats up and lubricates as intended?
Unfortunately I didn't get a good video capturing the audio, but sounds pretty much exactly as this video shows.
Tomorrow I am going to try to disconnect the driveshaft at the differential yoke and see if this does in fact silence the sparrows. If so, I will remove the driveshaft completely until the necessary parts come in to rebuild.
In terms of parts, I found these two kits. It seems the only difference between the two is that one have the Dana Spicers and the other one doesn't. They are the exact same price. Which one should I go for? Spicer or Dana Spicer?
https://www.dennysdriveshaft.com/p3...1310_series_includes_dana_spicer_211544x.html
https://www.dennysdriveshaft.com/p3..._for_jeep_with_oem_1310_series_non_greas.html
Does it seem I am going in the right direction to solve this problem?
