99 TJ shutting down
Lala23
Daytona Beach
I have a 99 sport 4.0 that started randomly shutting down, both while idling and driving at speed. Get no codes. It seems to be related to ASD relay. I replaced relay and had no problems for 4 months. Have done this twice but this time it is not fixing the issue. Something is causing the ASD to fail?? I'm at a loss now. Has anyone experienced this delightful defect? Thanks.
Start checking the wiring from the pdc to the wiring under the hood. Especially behind the valve cover. I have another electrical issue and that is what I have been doing. Looking for worn or broken wiring, grounds or sensor wiring and connectors. Get the FSM for the 99 available here and start reading. Good luck.
Note the post below-harness rubbing the stud behind the valve cover was an issue on earlier Tjs - if nothing obvious, disconnect the battery and pull the power distribution box and start tracing those ASD relay wires if all looks good under the box -
Keep us posted - helps us learn too.
