S SIDLULU New Member Joined Aug 8, 2019 Messages 19 Location LOUISIANA Dec 20, 2020 #1 I installed new a/c controls now the fan switch will not work. Put old back in same. Any thought's
CharlesHS TJ Expert Supporting Member Lifetime Supporting Member Joined Mar 10, 2020 Messages 5,602 Location Jacksonville FL, Quezon Philippines Dec 20, 2020 #2 You can download the FSM in a PDF from the forum in the TJ Resources section. https://wranglertjforum.com/threads...ice-manuals-fsm-technical-documentation.4618/ Then its time to break out the multi meter and start checking for where the voltage stops when selecting fan speed.
OP S SIDLULU New Member Joined Aug 8, 2019 Messages 19 Location LOUISIANA Dec 23, 2020 #3 CharlesHS said: You can download the FSM in a PDF from the forum in the TJ Resources section. https://wranglertjforum.com/threads...ice-manuals-fsm-technical-documentation.4618/ Then its time to break out the multi meter and start checking for where the voltage stops when selecting fan speed. Click to expand... Thanks short in wire.
