Hi everyone, so I’ll get right to the point. I’m going to be doing a sye and driveshaft real soon as my next project, and after reading through some other threads it brought up a question. Currently I’ve got a 4in suspension lift, with non-adjustable control arms. When I do the sye/ds, will I need to correct my drive angles(I.e needing adjustable control arms?) or is that only if I want to get rid of the 1in t-case drop along with the install of the sye/ds?
Second question...I just took my rig off road for the first time since I bought it in October. It’s a 4.0 manual on stock gears and axles(01 tj so 3.73’s and Dana 30/35) running 35x12.5’s. I noticed while out on the trails that at very low speeds in 4lo, pretty much any pressure to the gas pedal resulted in a rather jerky acceleration, like it was lunging forward. I’m guessing that’s from the improper gear ratio? 4hi was definitely better but I could feel at times while giving it just enough gas to crawl it would sometimes bog down(which I’m sure is partially normal, and I would give it more gas in that case).
So my question is, is it worth it to regear my current axles? Also, if I regear, and then further down the line want to build these axles up(stronger housing, better shafts etc) would I be able to do that separate from the regear? After wheeling for the first time yesterday in it, I’m in love and can’t wait to get back out there, but I want it to be as enjoyable as possible, and I’m all about improving my rig. So would it be worth it to regear soon(so I can wheel more comfortably for the next year or two(while I save to build the axles)?
