Hoping to have the orange '01 99% ready to sell after this weekend but have been daydreaming/planning for work on the '06 and have racked up a few question for the TJ sages:
1) Is it a bad idea to do an MML without a BL? I appear to have some amount of tummy-tuck (really need to get some measurements) but the body pucks look stock so I don't have any body lift. I was planning on replacing my stock motor mounts with some M.O.R.E units but was wondering if it might be a good idea to go for the 1" lift versions. I could see how it might potentially cause engine/tranny clearance problems and/or shifter alignment/clearance issues but that's really just speculation on my part. Anyone have experience or insight?
2) I know there are lots of you guys/gals with the Bright Silver Metallic paint and wondered if any of you had tried the DupliColor "Perfect Match" PS2 touch-up paint and, if so, how did it work? It's way cheaper than going with the Chrysler option.
3) Looking at several options for 15" wheels. I have to stay with 15" because I have a set of 5 brand new 33" X 12.5" Mickey Thompson Baja MTZ P3s that are 15". So, I'm wanting to get something with a bit of silver and a bit of black to reflect the color scheme of the Jeep and have been seriously considering the Vision Warrior 375's. Problem is that they are only 7.5" wide rather than the usual 8". Now, I'm guessing that half inch won't make much diff but, since I'll be mounting 12.5" wide tires, I figured I run it by the gang. Also wondering if anyone has had experience with Vision wheels or even the Warriors in particular.
4) OEM-like Rubicon stickers. The PPO had, for some reason, removed the original Rubicon stickers from the hood and put on not-quite-right replacements...in the wrong place. Here's a lovely night shot of what I mean.
Planning on replacing them and putting 'em back in the original position. Really want to get as close as possible to the OE stickers which, on my build sheet, are listed as "DARK SILVER METALLIC". Any thunks on best sources?
5) Thoughts on aftermarket service manuals: Generally I'm a Haynes manual fan and I have the Haynes manual (circa 2003) for my '01 TJ but I've been somewhat disappointed in it due to the fact that it was originally written around the YJ and does not seem to have been properly updated for the TJ's. Are the later editions of this manual any better (now covering through 2017; which seems to even further extend an over-extended model run) or are there other options that cover the TJs better. I am aware of the factory service manuals available for download on this forum and have downloaded them but just like the aftermarket manuals for day-to-day stuff.
That bees it for now but I'm certain that I will have more questions future (once I get to actually work on the Rubi). Thanks in advance!
