once you replace the cartridge install the top but don’t screw it down tight. Release the plunger and very slowly screw the lid down tight. Then depress the air bleed button on top until grease comes out. Then pump the handle. It takes a few minutes, but you’ll eventually figure out the sequence and timing and you’ll become quick at it.
Is your plunger cup facing the correct direction? One direction is for cartridges the other is for refilling with bulk grease.Did that a few different ways. I finally got it to bleed by unscrewing the entire bleeder valve most of the way and letting that make a mess all over itself.
That’s the right way for a cartridge. Are you using EP2 grease?Rubber skirt is facing down, away from the top.
That’s an EP2 grease. EP (extreme pressure). Try locking the plunger rod onto the plunger and push the plunger with your hand while depressing or turning the air bleed. For your region you may consider trying an EP1 grease. We used that during the winter months here.
