So, I have an issue with my passenger side door lock in my '97 TJ, it won't open from the inside by pressing the lock switch or by outside with the key in cold weather, it doesn't have to be very cold, even 32ish degrees. It isn't related to whether someone tries to open it first while it is still locked, like some folks seem to have a problem with. The key just doesn't seem to turn far enough when it's cold out to open the lock and the inside button won't press in far enough. I've lubed the crap out of everything with the door panel off, still no bueno. I have a feeling that one of the rods is just flexing a little more when it's cold and not putting enough pressure on the lock mechanism but it's hard to troubleshoot if it's cold and I can't get the door panel off because the dumb thing thing is stuck closed. Any thoughts?
Thanks,
Ray
Thanks,
Ray
