Oops, maybe I messed up. I'm American and my English isn't better.
I did do this in the same vehicle I wanted to undo the airbags. a 1996 Grand Cherokee.
My wife was pregnant, the Jeep had about 400 miles on it and I talked her into going up a hill. We got to the top and it started to rain. Coming back down was interesting to say the least. It wasn't going to stop no matter what. Luckily it wasn't too steep but it was very long and curvy. After that I started pulling the fuse until I found out how good the drum inside the disc emergency brake worked.
I just looked up the ABS fuses in my 2006 TJ manual, it shows:
#8- 40 Amp Green- ABS Motor
#12- 30 Amp Pink- ABS Valve
Unfortunately none of that seems to match your fuse box, hopefully it's just a year issue and not a import/export issue and someone with an older TJ can help.
